Today Only Deals
Hazro HZ27WB 10-Bit 27" Widescreen Professional Monitor - Black @ £311.99 inc VAT
With its amazing colour accuracy and versatile connectivity, the high-performance Hazro HZ27WB utilises the DELL U2711 panel which delivers stunning detail, depth and responsiveness. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. 100% sRGB and 96% AdobeRGB meets the needs of professional users involved in colour-centric work such as graphic design, CAD/CAM, gaming and media creation.
Features:-
- 27" CCFL 10-Bit IPS
- Uses DELL U2711 Panel
- Ultra wide gamut - 117% NTSC
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 80000:1
- Brightness: 350cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Dual Link DVI
- VESA Compliant
- Weight: 8.00kg
- Warranty: 2 Years
Only £311.99 inc VAT.
ORDER NOW
Patriot Viper Xtreme 16GB (2x8GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (PXD316G1866C9K) @ £71.99 inc VAT
Patriot's Viper Xtreme Series, Division 2 Edition memory kits are designed for Intel's® 2nd and 3rd Generation Core™ processors. Engineered for PC Gamers and enthusiasts the Viper Xtreme Division 2's utilize a custom designed heatshield solution with an outer shield built around a copper core to provide enhanced cooling. Each module has 6 grams of copper at its core paired with extruded aircraft-grade aluminum outer shield. Built from only using the highest quality pre-sorted IC's available, they are rigorously tested and validated on the Intel® 6 and 7 Series platform to achieve maximum performance and stability. These modules are engineered to reach PC3-15000 (1866MHz) at 9-11-9-27 timings and are available in 16GB kits (2 x 8GB). Each module is 100% hand-tested to quality assurance and is backed by a full-lifetime warranty and industry leading customer service.
- Extreme Performance PC3-15000 (1866MHz)
- Low Latency (9-11-9-27)
- Voltage: 1.55-1.65V
- XMP Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel® P67 and Z77 platform
Only £71.99 inc VAT.
ORDER NOW
Features:-
- VESA Compliant
- Weight: 8.00kg
- Warranty: 2 Years
ORDER NOW
- XMP Ready
- RoHS Compliant
ORDER NOW
