- 11 Dec 2005
- Cheshire
Today Only we have 20 units of the HIS Radeon HD 6950 IceQ Turbo 2048MB GDDR5, featuring the IceQ cooler which has near silent operation. Only £199.99 inc VAT.
We also have 30 units Akasa Nero 3 CPU Cooler which is compatible with every available socket type. With four high capacity heatpipes dissipating optimal levels of heat providing a cool CPU. Only £22.98 inc VAT.
HIS HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £199.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 840MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5120MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with FREE Deus-Ex PC Game (Subject to availability)
ORDER NOW
Akasa AK-CC4007EP01 Nero 3 CPU Cooler (Socket LGA775/1155/1156/1366/2011/AMD AM2/AM2+/AM3/FM1) @ £22.98 inc VAT
Akasa NERO classic design combines peak performance and near silent operation. A multi-platform cooler designed for the entire range of current Intel and AMD processors. The four high capacity heatpipes utilize direct CPU contact technology for rapid heat transfer. Direct contact eliminates thermal resistance thereby increasing efficiency. High grade aluminium profiled fins ensure optimum heat dissipation. A piano black 120mm PWM fan is mounted using anti-vibration siliconized rubber pins giving whisper quiet cooling.
The product design has been refined to ensure ultra quiet and exceptional cooling for CPU’s up to 150W TDP (Thermal Design Power). It is compatible with the new forthcoming Intel LGA 2011 processors. Akasa (patented) Easy Select Clip with Intel reference push-pin retention is used for no-hassle mounting on Intel LGA775, LGA1155, LGA1156 and LGA1366 platforms - no backplate is needed. AMD Sockets 939, AM2, AM2+ and AM3 are catered for with a cam-lever clip for safe and easy attachment. Performance thermal compound is supplied.
- Four high capacity 6mm heatpipes with direct CPU contact
- Piano black 12cm fan with PWM
- Siliconized rubber fan mounts for enhance ultra quiet performance
- Cooler dimensions: 120 (W) x 86.7 (D) x 160 (H) mm
- Heatsink material: High grade aluminium fins, copper heatpipes
- Heatpipe: 6mm x 4
- Weight: 609g
- Installation: Push pins (Intel LGA775 / 1155 / 1156 / 1366)
- Screws (Intel LGA2011)
- Cam-lever clip (AMD)
- Fan dimension: 120 x 120 x 25mm
- Fan speed: 500-1500 RPM (PWM controlled)
- Max airflow: 50.54 CFM
- Max air pressure: 1.32 mm H2O
- Noise level: 24.6 dB(A)
- Voltage rating: DC 12V
- Bearing type: Sleeve
- Fan life expectancy: 30,000 hours
- Fan connector: 4pin PWM
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- Heatpipe: 6mm x 4
- Weight: 609g
ORDER NOW
