With a huge 4GB of memory, the EVGA GTX 770 will be able to slice through any high resolution game like warm butter!
We also have the lowest price in the UK on the Corsair H100i Liquid Cooler bringing a dual rad into your system with easy installation.
EVGA GeForce GTX 770 Classified ACX 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-3778-KR) @ £419.99 inc VAT
Fast just got faster with the next-generation EVGA GeForce GTX 770, a high-performance graphics card designed from the ground up to deliver high-speed, super-smooth gaming.
EVGA is also introducing a brand new cooling design; the EVGA ACX cooler. This revolutionary double ball bearing fans with an average lifespan of 12 years. This is 4x longer lifespan vs competitors sleeve bearing fans! Not to mention this fan is silent, in factr it is 15% quieter on average!
The EVGA GeForce GTX 770 is stacked with unique gaming technologies like NVIDIA GPU Boost 2.0 that make it fast. Really fast. So nothing will hold you back from taking on - and dominating - your most challenging games.
Specification:-
- Core Clock: 1150MHz (GK104)
- Core Boost Clock: 1202MHz
- Memory: 4096MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2300MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £419.99 inc VAT.
ORDER NOW
Corsair Hydro H100i High Performance Liquid CPU Cooler (Socket 1155 / 1150 / 1156 / 1366 / 2011 / AM2 / AM3 / FM1 / FM2) @ £79.99 inc VAT
Extreme Performance CPU Cooling
Have a PC case that supports a top-mounted 240mm radiator? Take your CPU cooling to a new level. H100i starts with the advanced design of the Hydro Series H80i, and adds a double-wide radiator for even better performance.
Corsair Link Monitoring and Control
Monitor temperature and control lighting and fan speed on your screen. No additional hardware is necessary.
Self-contained Cooling System
Hydro Series H100i comes pre-filled, and never needs refilling or priming.
Dual Radiator with Custom Fan Design
The 240mm top-mounted radiator provides maximum surface area for maximum cooling power. The 120mm fans use wide, low-pitch blades for better static pressure to noise ratio, offering improved efficiency at lower noise levels.
Built-In Corsair Link
No additional hardware is necessary – just connect the included Corsair Link cable to a USB header on your motherboard and download the free Corsair Link Dashboard software. You can monitor coolant temperature and adjust cooling performance directly from your desktop.
Tool-free multiplatform magnetic mounting bracket kit
The modular design makes installation simpler, and it’s compatible with Intel and AMD processors.
Large-diameter, low permeability tubing
Minimal coolant evaporation helps ensure long life, and the resilient material offers both high flexibility and excellent leak protection.
• Corsair Hydro Series H100i High Performance Liquid CPU Cooler
• Magnetic Multi-platform mounting kit for all modern CPU sockets
• Dual SP120L High Performance Fans
• USB Cable for Corsair Link™ Compatibility
• Fan and radiator mounting screws
• Thermal compound (pre-applied)
• Quick Start Guide
• Technical Specifications
• Radiator dimensions: 120mm x 275mm x 27mm
• Fan dimensions: 120mm x 120mm x 25mm
• Fan speed: 2700 RPM
• Fan airflow: 77 CFM
• Fan dBA: 37.68 dBA
• Fan static pressure: 4mm/H20
Compatibility
• Intel™ LGA 1155, 1156, 1366, and 2011
• AMD™ sockets FM1, FM2, AM2, and AM3
*Hydro Series H100i requires a case with dual 120mm fan mounts with 15mm spacing for a 240mm radiator
Only £79.99 inc VAT.
ORDER NOW
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
• Quick Start Guide
Compatibility
ORDER NOW
