TODAY ONLY DEALS - 18/08/2010 - OCZ & LG LED Monitor!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Two great quality products on offer today, they both exclude free shipping but at these prices you can see why:-
LG E2240T 22" Widescreen LED Monitor - Black @ £117.49 inc VAT
LG’s new LED LCD Monitor employs LED backlight panels that displays incomparably clearer pictures than CCFL panels and its mega contrast ratio of 5000000:1 and Full HD resolution makes sure that you get clarity beyond comparision. LED is an Eco-friendly technology that does not use any halogen or mercury and moreover, it saves energy consumption by more than 45%
Features
- LED Backlit
- Screen Size: 21.5" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 529.8 x 410.3 x 202
- Weight: 2.8kg
- Warranty: 3 Years On-Site
Was [£126.89] Inc. VAT
Only £117.49 inc VAT.
ORDER NOW
OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply @ £56.39 inc VAT
The ModXStream Pro Series is the superlative solution for driving today's gaming systems, and can power both NVIDIA® SLI™ and ATI CrossFire™ modes. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 140mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 86% efficiency at typical load and up to 82% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
The OCZ ModXStream provides Universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power. Available in configurations ranging from 400W to 700W and backed with OCZ’s 3-year “power swap” warranty, the OCZ ModXStream Pro gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- 150 x 160 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- up to 86% Efficiency
- Overvoltage/OverPower/Short-Circuit protection
- (.99)Active PFC
- MTBF: 100,000 hours @ 25C
- 1 x 20/24-pin ATX
- 1 x 8-pin CPU
- 1 x 4-pin CPU
- 1 x 6-pin PCI-E
- 1 x 6+2-pin PCI-E
- 4 x Peripheral
- 2 x Floppy
- 6 x SATA
Was [£64.61] Inc. VAT
Only £56.39 inc VAT.
ORDER NOW
Ideally you should be using the AX1200 as it's designed more for using 3 cards. The GTX 460 doesn't require tremendous amounts of power though so you may get away with it using some splitters - the AX 850w is a very high quality PSU.
OKay, beautiful idea forming, upgrade my server to 850 then upgrade to 1200 when they are in stock and move 850 too mine and flog 450w bequiet....
simples
Thanks for your order. :)
Tbh i,m tempted with the Psu as well but when you add £8 in postage its actually cheaper when its not on offer...:rolleyes:
Still for newcomers there are some superb deals coming up.
We're trying to make things fair all round. When we've done forum exclusive offers we get critcised by new members and when new customer offers get posted forum members get disgruntled because they've been so loyal. If we do both then everyone is happy!
