Check out todays deals!
MSI HD 7970 Lightning BOOSTED Edition 3072MB GDDR5 PCI-Express Graphics Card @ £419.99 inc VAT
Key Features
Unlocked Digital Power
- Unlocked BIOS: One click to unlock all protections for extreme overclocking
- Digital PWM Controller: More stable and precise voltage by digital signal
- Enhanced Power Design: 2X Power output for maximum OC potential
GPU Reactor
- An add-on device on the back of R7970 Lightning (Behind GPU) for the overclocking stability
- Provide 88% higher power capacity and eliminate power noise (ripple)
Xtreme Thermal
- Dust Removal technology on Twin Frozr IV keeps dust out for the best thermal condition
- Dual Form-in-one Heatsinks provide better heat dissipation and strengthen the structure
Military Class III Components
- Meet MIL-STD-810G standard to ensure the best stability and quality.
- Adopt CopperMOS, Hi-c CAP, Golden SSC, and Dark Solid CAP
Specifications
Graphics Engine ATI Radeon HD 7970
Interface PCI Express x16 3.0
Memory Type GDDR5
Memory Size(MB) 3072
Memory Interface 384 bits
Core Clock Speed(MHz) 1070
Boost Clock Speed(MHz) 1150
Memory Clock Speed(MHz) 6000
DVI Output 2
Mini DisplayPort 4
HDCP Support Y
HDMI Support Y
Display Output (Max Resolution) 2560x1600
RAMDACs 400
DirectX Version Support 11
OpenGL Version Support 4.2
CrossFire Support Y
Card Dimension(mm) 305x135.5x40mm
Warranty 3 Year
Only £419.99 inc VAT.
ORDER NOW
Hazro HZ30Wif 30" LCD Widescreen Professional Monitor - Black @ £599.99 inc VAT
The Hazro HZ30Wi is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30Wi performs with consistency and clarity to optimise your visual experience. The Hazro HZ30Wi recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30Wi collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30Wi, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30Wi offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30Wi is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Features:-
- LCD Panel: 30" WQXGA colour LCD S-IPS active matrix
- Type: 16:10 aspect Ultra wide gamut TFT-LCD
- Viewing area: 641.28 mm (H) x 400.8 mm (V)
- Resolution: 2560 [H] x 1600 [V]
- Pixel Pitch: 0.2505mm x 0.2505mm
- Contrast Ratio: 1000 : 1(Typ.)
- Refresh rate: 59 ~ 60 Hz
- Response Time: 6ms [grey-to-grey]
- Color Gamut: Wide Gamut 117% (CIE 1976) NTSC [100% AdobeRGB and sRGB Coverage]
- Brightness: 370 cd /m² (Center 1 Point)
- Viewing Angle: R/L : 89°/ 89°U/D : 89°/ 89° (178°/ 178°)
- Surface Treatment: Hard coating(3H), Anti-glare treatment of the front polariser
- VESA Hole Configuration: VESA 100x100 & 200x100
- Dimensions: Approx: 690(L) x 445(W) x 65mm(D) (excluding stand)
- Weight: Approx 11 kg before packaging and excluding stand [approx]
- Power Consumption: In Operation: <150W
- DPMS / OFF: <2W
- Energy Saving Mode: VESA DPMS [Display Power Management Signaling]
- Power Input/Output: DC Input: AC 100V-240V, 50~60Hz, DC Output: DC 24V / 6.3A [approx]
- Inputs: 24V DC Jack, 1 x Dual Link DVI-D;
- Accessories: 1 x Dual Link DVI-D Cable; 1 x IEC 3 Pin AC Power Cable;
- 1 x DC Power Adapter; Instruction Manual
- 3yr Warranty
- Read the TFT Central Review here: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
Only £599.99 inc VAT.
ORDER NOW
Key Features
GPU Reactor
Xtreme Thermal
Specifications
Memory Type GDDR5
DVI Output 2
Mini DisplayPort 4
HDCP Support Y
HDMI Support Y
RAMDACs 400
CrossFire Support Y
Warranty 3 Year
ORDER NOW
Features:-
- DPMS / OFF: <2W
- 3yr Warranty
ORDER NOW
