- 31 May 2009
An issue has developed within my toilet, (hurr hurr) all has been fine for years, then a stage where you had to push twice quickly to get it to flush, and now it won't flush at all, unless you take top off and push ballvalve down to overfill the cystern.
I figure the problem relates to a Split Diaphragm or broken Siphon, unable to determine which, as I drained the ******, and then went to try and remove the Siphon and find I am totally unable to do so.
I was expecting a blot externally, or some form of nut to undo, but I am unable to find any such thing. The cistern sits directly on top of the bowl, and although not fused, are tight to one another.
I can't set the ballvalve to allow the cistern to overfill either, as when the water reaches a level it start to run and drip into the bowl as some form of overflow mechanism.
Trying direct pressure to remove the siphon doesn't appear to budge it either, and i don't wish to break the thingtrying to remove it.
Any suggestions on how it is retained and how to remove/replace it?
