Tom Tom Stuck - Need Help
29 Sep 2004
Wilt of the Shire
I turned on my Tom Tom One V2 but it's just stuck on screen that shows the TomTom logo and I can't turn it on or off. I've tried to do a reset but that didn't work. The TT software doesn't show it as attached to my pc either. Data loss is not a problem as I have it backed up. Anyone help me out here?
Mine has done this once before, I took it apart and disconnected the battery inside. Problem solved.
That's an old tomtom one though, I'm not sure how easy the new ones are to get at.
Cheers, did this and all sorted now.
