Tomato Firmware 1.26
12 Aug 2008
Just noticed a new firmware update, thought i'd share :)
Code:
Version 1.26
Allow a different port to be entered in Basic:Network:Static DNS (enter as "ip:port"). Be aware that dnsmasq must act as the DNS server (the default setting) when not using the normal port 53.
Allow DHCP to serve the user-entered gateway (in Basic:Network) if the option in Advanced:DHCP is enabled.
Do not start miniupnpd early to avoid warning messages.
Update Australian DST (need to re-select), add Darwin, Brisbane TZ. Thanks to Peter O. for the info.
Avoid double loading of tomato.css
Fix possible null dereference in sendpage
Collapsed all menus. For the old look, set nvram: "web_mx=status,bwm,tools"
Obscured some key/password fields when not in focus.
Accept more than two MAC addresses per IP address (ex: one IP for a laptop either wired or wireless [one at a time]). Note: Some computers may not like seeing the same IP unless it's restarted.
Added LED options back in Admin:Buttons/LED.
Added ID for WLA2-G54L, TrueMobile 2300 thanks to Nick B. and David J.
Added EditDNS thanks to Keith M.
Added UTC+4:30 Kabul time zone.
Fixed port set validation allowed more than what could be handled.
Allow rstats to log if WAN port is used for LAN.
Update dnsmasq to 2.51, miniupnpd 1.4, busybox 1.14.4, matrixssl 1.8.8.
http://www.polarcloud.com/tomato_126
Can't? Type tomato into google and it's second on the list... http://www.polarcloud.com/tomato Yes it's supported, although I'd read the instructions carefully for a non linksys.
I should point out Victeks RAF mod is having it's last few checks before it's 1.26 incarnation. If you want the bandwidth limiting by mac/other useful tweaks..
2nd on what list? and i can now see 1.27?
Download
(please don't link the files directly - Thanks)
Firmware
Tomato_1_27.7z (3MB)
SHA1: c84b9075aaa6d24b1fb7278c9259ba6f46fa0995
» Use this for most routers.
» See NOTES above.
Tomato_1_27_ND.7z (3MB)
SHA1: 76f09a2ab668dc77b2f548a4ed45c009d0c56cd4
» Use this for WHR-G125, WL520GU.
» May not work with some routers, use extra caution.
» See NOTES above.
When you goole tomato the site is the second one listed. How anyone can go to the tomato site and miss the list in the center of the page idk:
Routers that are known to work with Tomato:
* Linksys WRT54G v1-v4, WRT54GS v1-v4, WRT54GL v1.x, WRTSL54GS (no USB support)
* Buffalo WHR-G54S, WHR-HP-G54, WZR-G54, WBR2-G54, WBR-G54, WZR-HP-G54, WZR-RS-G54, WZR-RS-G54HP, WVR-G54-NF, WHR2-A54-G54, WHR3-AG54
* Asus WL500G Premium (no USB support), WL500GE, WL520GU (no USB support)
* Sparklan WX6615GT, Fuji RT390W, Microsoft MN-700
yeah i could see all that mate, but just wasnt sure which
Firmware
» See NOTES above.
» See NOTES above.
As they both say see notes above. Sorry for being a bit over cautious but obviously i wont want to brick a router.
can i upgrade to this and keep my settings? or do i have to make a backup of my config then reapply it after installing 1.27?
An update should be fine and keep all your settings. Double check any readme files in each release for different instructions. Make a backup just in case.
Vesrion 1.27 was quickly released yesterday with a fix for something that was previously missed.
If the settings are going to be lost or a NVram flash is needed, it always says in the release notes
god its hard to get the timing right on the buffalo one. Ive given up for the time being why couldnt it be simpler.
