fullfat said:i have, are you on about the end boss?
nice sig btw![]()
McDaniel said:found it easy, took about 2 mins, just keep swiping at her non stop and dodge her attack, then stab 4 times
voila![]()
Neon said:stab four times when she hits the floor?
SiD the Turtle said:Don't spam the mouse firing off bolts. If you are close to a pillar it will severly hurt you. Hide behind said pillars is one tactic, but I couldn't get the hang of that. I find the best method is to stay near the middle and be agressive with it. Avoid the edges like the plague as there's nothing as annoying as almost killing it and then being blasted/jumping off of the edge.
Energize said:I found out that I really needed a joypad for these type of games.![]()
Pigeon_Killer said:I started playing this a few days ago but I kept getting flashing textures at the top and bottom of the screen. I thought it was down the new graphics card I bought but I've not had the problem in FEAR, NFSMW or any of the 3DMark tests I've run. I'm hoping they'll release another patch that will sort the problem because it's doing my head in.
Pigeon_Killer said:^ Cheers mate![]()
