19 Mar 2006 at 15:50 #1 Lt. Manlove Lt. Manlove Associate Joined 2 Oct 2003 Posts 2,121 Location Chester How can you install information on TomTom GPS 300 to tell you where the static speed cameras are?
19 Mar 2006 at 15:55 #2 triggerthat triggerthat Soldato Joined 26 Aug 2005 Posts 6,901 Location London http://www.pocketgps.co.uk/tomtom-go-poi.php I have this on my tomtom one. It works very well.
19 Mar 2006 at 16:04 #3 Lt. Manlove Lt. Manlove Associate OP Joined 2 Oct 2003 Posts 2,121 Location Chester Cheers, this is perfect.
19 Mar 2006 at 16:20 #4 Lt. Manlove Lt. Manlove Associate OP Joined 2 Oct 2003 Posts 2,121 Location Chester Can you give me a quick hint how to do it? Not much luck!
19 Mar 2006 at 16:25 #5 great advice great advice Soldato Joined 20 Oct 2003 Posts 2,872 Location Manchester Lt. Manlove said: Can you give me a quick hint how to do it? Not much luck! Click to expand... Did you check the readme file? its quite clear as its just a drag and drop of the files jobby
