Tomtom maps and N73
19 Jan 2005
Got my SD card this morning so have been trying to get tomtom working for the past 2 hours or so now, gettin a bit mad, finally got the program on but cant get it to recognise the maps. The instructions I had said to just "Use any map which is already released for PPC and place in root of your memory card." My map (UK and WE) is 29 files and 290mb. I put them in the root of my memory card and I just keep getting no maps found error message.
I then got tomtom home from their website and installed that but it said it could not find a compatible tomtom device so that ruled that out.
Anyone know how to do this?
Be very grateful.
tried that, put them in a directory in the root called Western_Europe-Map as I was instructed to somewhere else, that didnt work, then changed it to just map and that hasnt worked either. I dont even know if I have the right files yet, these are the filenames I have:
cline.dat
cname.dat
faces.dat
mapinfo.dat
poi.dat
tmccodes.dat
traffic.dat
MapSettings.cfg
GB_plus_Major_roads_of_WE.mms
Safety_Cam_UK_30_TomTom.ov2
GB_plus_Major_roads_of_WE.pna
Do these look familiar to anyone? Cheers
Just looked at the files I have on my pocket pc and there seems to be another file called GB_plus_Major_roads_of_WE as there are three of them. I dont have any of the Safety_Cam_UK ones either but have loads called POCKET_GPS_UK and POCKET_GPS_EUROPE. This is on Tomtom Navigator 6
