tomtom mobile 5 and seperate gps recievers
jmp
jmp
10 Jan 2005
In the glovebox
If i buy a bluetooth gps reciever and then get hold of the TomTom Mobile5 software seperately, can i just put it on my phones memory card and run it or does it require reg codes and subscriptions. i know they supply it on a miniSD which is fine but i dont want to swap memory cards every time i want to use it. i'm not sure if getting the satnav on my phone is really worth it. I'm planning on travelling around the UK in the summer so it would be handy.
My experience with TomTom Mobile 5 on a Nokia N70 is not good. It crashes very often. There are many posts on other forums about this problem. It does not appear to crash if I turn off the 3D Map though.
I use a third party bluetooth gps reciever. It might be better with the TomTom reciever but I doubt it.
