Hi
I bought one of these units today.
I've used it a couple of times to get familiar with it and it's great.
I like to simple to use interface.
However, i find the user manual absolutely rubbish. To be fair though the Tomtom is so easy to use that you dont need to look at the manual but i just need a couple of questions to be answered.
1. When charging the TomTom via the USB cable it doesnt say on the unit that is charging.
All i can see on the screen is a picture of the tomtom with the usb lead connected to it.
Does this mean it is charging ?
2. How long does the battery normally last for?
3. How often are updates available to download? I have updated my unit since buying it.
Thanks
Thanks
