Just bought a TomTom One v2 from Halfrauds this morning.
Got home, installed the CD and connected it via the USB cable. Wanted to download and install the speed camera notification but before I could it told me there was a new update for the software available. Clicked on download and then installed the update.
It seemed to be going fine, then the screen went white and appears to have locked up. The power button is showing the green led on all the time, nothing is happening with it.
Tried the reset button underneath, white screen is now gone, but power led is still lit up and nothing happens when I press the on/off button.
Not a good start considering its only been out the box for under an hour!!!.
