Hi
I've had a look around but I can't find anything so I'll put the question to you guys.
Is there a way to plan a route (itinerary) on a pc, and then transfer it to TomTom Navigator on my PDA?
I know you can use TomTom Home on the standalone units, but I can't get it to work on the PDA version.
I like planning routes down country back roads, but longer trips can get a bit confusing on the PDA screen.
Thanks
Steve
Edit: I'm using TomTom Navigator 6 if that makes any difference.
Thanks
Steve
