Too Hot?
22 Jan 2008
King's Lynn, Norfolk
My 2 year old Dell D610 gets incredibly hot when performing heavy tasks such as Gaming and Media conversion.
Under heavy load, here's a guide to how hot it gets:
The CPU easily reaches 85 degrees Celsius
The GPU gets to about 67.
The Memory gets to 65.
The Chipset gets to 67.
The Hard Drive gets to about 49.
Is this really too hot?
The laptop is running XP Pro SP3, with Speedstep enabled and the power setting on Laptop.
It's always placed on a wooden desk, with plenty of airflow.
I've cleaned the fan on many occasions, the most recent being only 3 weeks ago.
I'm just hoping your right about it being OK, seeing as most electronics will suffer when they get even close to 85C lol.
if you run a bench test and then stop it does the temps drop significantly? this would indicate the heatsink is doing its job, i would only be worried if no hot air is being vented, the chasis on most laptops are metal of some sort and have shielding that will disapate heat as best it can so it will feel like the entire laptop is hot, this weather doesnt help either, i run a yate loon cooler pad on mine as it keeps the base and palm rest cool also.
Yeah, I was pretty sure the heatsink was OK, mainly because of the drop in temperature when not in use.
How much of a temperature drop did you get from your laptop cooler, if you don't mind me asking?
i dont think it would make much diference to actual cpu temps i didnt measure it but the casing without it would get quite hot and with it is much much cooler, i guess it stops the heat building up, also when using it on your lap or in bed your not blocking the vents it just powers of the usb and isnt too noisy either.
It should start crashing long before it breaks I would think. CPU/video/hard-drive temps look normal, dunno about chipset/ram since I've never checked mine.
I know most desktop video card chips have a thermal shutdown temp of about 120 degrees, and regularly run up to 80 degrees with the stock cooler. So it wouldn't be correct to say 85 degrees is the point where all chips get damaged.
Aww, thanks for clearing that up for me.
It's still pretty funny to hear that Desktop users have their PC's shutdown at roughly 65C xD
My Toshiba which is simailair to this does exactly the same, this is with both cores under 85% load using the intel test tool. As long as it doesnt turn itself off your fine.
