I have recently bought a Aquaduct 720 XT which is a large external radiator with inbuilt pump. My desk is located in front of a window which is just to the right and I want to put the radiator here meaning that I need the watercooling hoses going behind my desk.
My watercooling system includes a CPU block, a watercooled GPU and a 250ml reservoir. Plus the long hoses. I use 16/11mm tubing and compression fittings (G1/4).
After installing the radiator, I switched it on and checked the sensors in the radiator. At first it was low-ish, around 32 l/h but then it started dropping, until it hit a total of 0 l/h. I manually set the frequency of the pump to the max (74 Hz) which seemed to do something, however it still idles at 26 l/h which is past the alarm-level (30 l/h).
