Hi all, I am trapped in the land of monitor indecision and really need help (I did a rushed post previously when my monitor died, but now that I am borrowing my brother's old one I have had time to give thought to my options and hopefully get help from those far wiser than I!)
First things first, my current specs are:
i5 CPU (whatever was latest in Jan 2015, a bit embarrassing I cannot remember which one considering I built the PC myself)
GTX 970 factory OC
8Gb RAM
In terms of use, it is gaming and internet browsing. Mainly MMOs rather than FPS which I only dabble in occasionally. For this reason I do not feel a 144hz is of great importance to me so I have not spent much time focusing on them.
I was using a 21.5 LG 1080p monitor which is like 8 years old, it has decided to retire itself.
It is worth noting, that previously I did buy a 32 inch Samsung monitor, but it was faulty and I returned it. My impression of it was that it was too big overall (I think primarily the vertical sizing) resulting in head movement to soak everything in.
Ideally my budget would be below £400 (especially if not going with 34 inch ultrawide)
So, I am looking for a new one, my initial thoughts was a 27 inch 1440p monitor, having investigated a few, it seemed the Asus PB278Q looked to be a contender as its response/lag combined seemed to have minimal side effects.
Asus is under £400
https://www.overclockers.co.uk/asus...l-led-multimedia-monitor-black-mo-077-as.html
I then started thinking 21:9 would be pretty nice, the most affordable being the Lg29 ultrawide.
https://www.overclockers.co.uk/lg-2...e-widescreen-led-monitor-black-mo-143-lg.html
There seemed to be 2 versions:
Flat at around £250
Curved around £330
My concern with the 29 inch is:
Firstly, the screen is too small to bother with curve? I get the feeling I would be paying for the cool factor of the curve without any need for it and if paying that higher price it is too close to the 27inch 1440p.
The other concern is the fact it is only going to be the height of a 23 inch monitor (now, being used to 21.5 inch I guess this is not an issue, but given the choice between that and a 27 1440p I am not sure Ultrawide at such a size is worth it?)
The natural progression was to look at the 34 inch Ultrawide monitors, as I think the smaller vertical will remove the issue I had with the 32 inch Samsung. Of course, not surprisingly, the only ones with a sub £400 are 2560x1080 (so the same as the 29 inch but much bigger) my natural inclination is that they have too low a res.
The closest 'affordable' 1440p was about £550, obviously this was not curved which actually raises a concern opposite to the 29 inch screen - at 34 inch is it a bit too wide without a curve to bring it in a bit? (Having said that, a B Grade curved monitor in Clearance at this website for £599 is a cruel tempter)
A downside to the 34 inch of course would be the power output needed from my GPU. I am not overly precious about reducing quality in a game to keep things smooth (within reason-I don't want to run things below Medium). On the other hand, if a game is too much I could always use standard 1440p res and get the same as I would have on a 27 inch monitor, albeit with black lines on the side.
So, as you can see I have got myself tied up in 'ooh but what about that one!' hell and could really do with someone slapping some sense into me, so any help offered is appreciated!
GTX 970 factory OC
8Gb RAM
Asus is under £400
Flat at around £250
Curved around £330
Both have acceptable response times for that sort of gaming, imho, and as yet I've never found fault with Dell.
