- 13 Mar 2012
Hi all,
I'm moving back to air cooling, and wanted to run the above set up by you. I had a load of 140mm Noctuas from past builds and thought I might as well max out the cooling space, but I'm a bit worried it'll be self defeating.
That's a 3090 FE and a Noctua D15, which both dwarf the case.
There's two Noctua A14s at the front set as intake - one is directed underneath the GPU to feed the two fans, and the other is aimed at the CPU cooler. I'm hoping the exhaust from the GPU won't affect the CPU cooler too much.
The exhaust are 3 P14s. My main worry was about the top two exhaust fans. The left one doesn't look like it'll be doing much, and the right one could end up just exhausting cold air from the intake that could have gone through the cooler. Would you set the right one as intake? Or just not have them at all?
Obviously I'll experiment a bit when it's up and running, but there's a lot of variables so I thought it would be better to draw on experience!
