Too Many Hops???
12 Sep 2003
Newcastle, UK
Hi all
I have been trying to email a companies support email address (regarding an order which has not turned up) and I have received the following back...
Returned mail: Too many hops 26 (25 max)
What does this actually mean? Can I do anything? :(
Thanks. :)
Firegod said:
Hi all
Thanks. :)
Not entirely up on this, but a hop is like a stop off point for routing traffic#
like this...
traceroute: Warning: www.google.co.uk has multiple addresses; using 209.85.129.147
traceroute: Warning: Multiple interfaces found; using 212.74.64.46 @ hme0
traceroute to www.l.google.com (209.85.129.147), 30 hops max, 40 byte packets
1 fe5-0-svc2.LON.router.COLT.NET (212.74.64.33) 0.660 ms 0.548 ms 0.414 ms
2 fe6-2-cr1.LON.router.COLT.NET (212.74.64.214) 0.568 ms 0.322 ms 0.334 ms
3 pos1-0-pr2.LON.router.COLT.NET (212.74.64.77) 0.631 ms 0.616 ms 0.824 ms
4 195.66.226.125 (195.66.226.125) 0.934 ms 0.864 ms 1.645 ms
5 72.14.238.242 (72.14.238.242) 1.169 ms 0.834 ms 31.972 ms
6 216.239.43.91 (216.239.43.91) 51.929 ms 9.209 ms 9.217 ms
7 209.85.248.183 (209.85.248.183) 15.996 ms 16.785 ms 16.110 ms
8 72.14.232.207 (72.14.232.207) 16.992 ms 16.773 ms 16.939 ms
9 72.14.233.210 (72.14.233.210) 16.486 ms 16.013 ms 18.020 ms
10 fk-in-f147.google.com (209.85.129.147) 17.993 ms 22.021 ms 17.855 ms
1 to 10 is a hop.... theory should be that you should go through a certain amount to reach your destination aka your e-mail.
Try resending again....
sorry not too much help there...
The "hops" in this case is the number of mail systems your e-mail has passed though. The usual cause of this is a mis-configured relay in the line somewhere - assuming the e-mail address is valid.
The error message should have included the headers of the original message and this will indicate where the problem is.
