Too many HTTP redirects
26 Oct 2002
Corby Glenn
As subject really.
In the App Store from our IP5, I click on an app to view it and a pop up box says simply that?
Anyone got any ideas?
Our iPad still works fine
Jb
I had the same problem, and found it quite frustrating. You could try logging out of your account first by signing out via Settings -> iTunes & App Stores, closing the app store manually (double tap home button, hold app down and 'minus' it) and turning off & on the phone again.
Unfortunately for me, this didn't work - and after spending a while at it, I got fed up, backed up my phone via iTunes and restored. This fixed the issue. However in hindsight, something I forgot about was to 'soft reset' the phone. I would give this a try - just hold the sleep and home button until the phone switches off and release, it will then restart.
I couldn't figure out exactly how it happened in the first place, but I think it was because I tapped a link to an app via Safari that wasn't available in the UK app store, and it went a bit mad.
Hope this helps.
Hope this helps.
this is what i did in the end which did sort it.
seems a lot of people are having the same issue.
thanks for the help.
jb
