Hi All,
I’m just setting up a new (to me with now old tech) rig and as I didn’t want to purchase a new case, I have have modified my old one by removing one side of the hdd rack to get the dual gtx980 cards in. Whilst I was at it I was wondering if it was worth utilising the redundant 5.25” bay for an additional 140mm intake fan? (Slight modification required).
The current (original) setup of this old Antec 300 case consists of (see pics):
Intake: 2 lower 120mm fans and 1 side 120mm
Exhaust: 1 upwards facing 140mm fan and 1 rear facing 120mm fan.
Looking at the first pic, the red arrow shows the proposed addition 140mm intake fan slaved in position but I thought I’d ask here if the voices of experience thought it was really worth it. It will be filtered and shrouded in much the same way that the lower 2 are.
The stock case design has a positive intake pressure so this will further increase that but maybe by too much? Spec wise, ignore the EK cooling block on the CPU as that’s going and being replaced with an NH-D15. Board is an ASUS X99 Sabertooth, i7 5930 and 2 GTX980ti.
Any advice welcomed.
Regards
Joel.
Regards
Joel.
