- 30 Dec 2003
- Bigger box!
So, putting together a PC with a 3700x and an RTX 2080.
Currently have a 60 Hz 1080p monitor, and obviously need a major upgrade.
Budget isn’t a massive problem, but I’m really trying to get bang for buck with this build. That’s why, for example I’ve gone for the straight RTX 2080 and not a Super or even Ti. I just don’t think the extra expense is worth the performance boost.
I don’t want to spend more than I need to, but of course it’d be stupid to scrimp and not take advantage of what should be (currently) a fairly high spec PC.
I expect (hope) the monitor will outlast the graphics card, so something a bit future proof would be great, but I’m certainly not willing to fork out the £2k + for one of the top of the range all singing, 200mhz, ultra wide, bad boys.
I also don’t think I want 4k. It’d be a shame to put this PC together and still be playing at 60 FPS.
I did think that the https://www.overclockers.co.uk/lg-2...le-widescreen-led-gaming-monit-mo-155-lg.html was the move, and still possibly do.
Research is steering me towards Ultra Wide though. In which case the Alienware AW3418DW might be the move.
It’s likely to be on sale at some point and I’m in no massive rush to get this done, so fits nicely into the ‘bang for buck’ motif.
I also like the idea of the Predator Z35P, but it seems suspiciously cheap with most places selling it sub £600 right now.
Am I missing a major flaw or draw back?
My only concern with these ultra wides is the refresh rate. I think I’d like 144hz, but having never played over 60hz before I’m simply going by what I’ve read...
I really wanted the Razer Raptor (google it) for the aesthetic, but there’s been no need since January.
I am however willing to wait if there are good contenders on the horizon...
So, TL;DR, new PC with 3700x and RTX 2080, pretty much just for gaming. Can’t decide on a screen, don’t want 4K... Go!
