Too much oil?
19 May 2005
Hi all,
I bought a 3yr old 330d a few weeks ago from Car Giant, and I checked the oil last week, and again today. It seems that it's above the maximum mark on the dipstick. I originally put it down to being on a bit of a slope, but it's the same on a flat surface.
It's probably 1cm over the maximum mark. Will this be seriously detrimental to the engine, or not, I'm assuming it will be...
I've probably done about 1,000 miles in it so far, and I've not noticed any problems. Will Kwik Fit be able to sort it out?
Many thanks in advance,
Nick
Oh cool (phew).
Lol at Kwik Fit, do I not just need some monkey to drain a bit of oil? I would do it myself but I don't want to get oil on the drive + I'm not 100% sure how to do it/how much I should drain.
Nick
Have you noticed any oil leaks or excessive oil burning or clutch slipping?
If not it's more than likely ok, get a garage to drain the excess, no problem.
I wouldn't worry about it, leave it as it is.
Vauxhall used to constantly over fill my Astra at pretty much every service to about 1 litre over, it uses some oil so i left it it, never needed to top it. :p
Mind you the turbo did die @ 138k, :( but it took a lot of abuse from me, 5 to 138k miles in 44 months, but still on original clutch :)
Nothing to do with overfilling the oil.
I've not noticed any of these. I'm just going to leave it. I had another check, and it's about half a cm now rather than the full 1cm I said earlier.
I'm going get the oil changed soonish anyway - so I'll leave it till then.
Many thanks guys!
Nick
Get the oil drained out - might as well just change it. Too much oil can be as bad as too little. Why risk such an engine and car for the price of an oil change?
I would say you should change it and get it below the maximum mark. At work where we work on a lot of diesel generators all the guys I work with have said being overfilled can be be bad for the engine.
I've always been led to believe too much oil can lead to excessive oil pressure, which can blow seals and suchlike. Just have the oil changed and filled to the correct level, not point cutting corners on a car like that.
Exactly what happened on mine. Luckily it didn't totally blow, just made one of the seals wheep all the time.
I have read that over-filling modern diesel engines can be very harmful but I have no idea why this might be nor any evidence to back it up.
