Got a bit of prob with my rig, looking for advice on possible reasons for the problem please. Sorry in advance for long post! (Spec in sig.)
On Saturday, was using the PC in the morning, everything working fine, temps all normal (using MBM5.) Shut it down, went back to it a couple of hours later, evrything seemed normal. Left it to go answer the front door when the kitchen fitter arrived, suddenly hearing beeping. MBM alarm is showing the CPU temp as 70C
. At idle. Double
Ran Speedfan, used the various logs in MBM and Speedfan - all the fans are running normally, SMART on the single HDD is reporting a temp of about 45C, RAID array doesn't get picked up though, the GPU drivers say it's running 52C, MBM says the air temp in the case in the mid-50s, the CPU in the high 60-s.
Shut it down, left it a bit. Rebooted and the temps look normal. But they climb steadily but slowly so that after about five minutes, the CPU is running at 70C and the air temp in the case is in the 50-s again. That's with leaving the system idle the whole time.
Yesterday the wife rebooted when she saw the alarm (even though I'd asked her not to use it but stick to the laptop!) but then left it running. We were in the lounge when I heard the BIOS beep. Strange. Then it did it again about 10 secs later. So it's obviously reset itself twice. Had a look at the temps - cpu now at 80C
Was trying to change the config on MBM to shutdown the pc when the temp hits the alarm (it won't let me, anyone know how to this properly?) when suddenly it BSODs! Can't remember the exact phrase now but it was something like "page fault in non-paged area." The stop code was 0x0...050 (can't remember how it's structured, just remember it ended in 50)
Can't actually get near the pc to strip it down as I'm in the middle of decorating and there's stuff everywhere, but the fans all appear to be running normally, just something is getting too toasty!
Any ideas? Help!!!
. At idle. Double
Any ideas? Help!!!
