took 7 degrees off CPU temp ...
Suggests the airflow in your case isn't so great. A good thing to try out though.
The other options are shrouds (as far as I know untested on heatsinks) and using a fan either side.
Turn off the side fan and tape a piece of card over it, see what happens to the temperatures then. Should be a fair bit better.
The fans pointing downwards on the ram probably explain why pulling worked better, you may find that turning the ram ones off and putting the fan pushing through the cooler works better again.
