Bonjour,
Need to take my alloys off to change the callipers and pads, but I can't get the wheel off; the knuts have been tightened up to the - well, knuts! Problem being, the actual knuts are recessed in the wheel, so the tool I use can't be much wider than the ****. Some sort of power tool has obviously been used to take it off, as I can't create enough leverage to get it off!
Pic of the alloy in question:
I'd like to get it off by tomorrow evening, so can anyone recommend a tool that I can pop in to a shop and buy?
Ta!
Ta!
