How do people install their SSD's in their PC's? I've heard about Velcro and tape but I have a HAF 922 with tool hard drive bays so it would be nice to be able put it in the drive bay, so.....solutions and ideas?
I used a screw either side in the middle, but to get the little rubber grommet/push pin to fit into the front screw hole i had to just use a drill bit big enough to remove the thread within.
