5 Dec 2011 at 15:16 #1 Jon123456 Jon123456 Associate Joined 5 May 2011 Posts 133 There are a few programs that I use again and again. Any recommendations on what a good toolbar/launch bar would be? Thanks, Jon
5 Dec 2011 at 15:51 #2 mrk mrk Man of Honour Joined 18 Oct 2002 Posts 106,918 Location Uranus hehehe You post makes no sense! If you use Windows 7 then just pin items to the taskbar and launch them using WINKEY+1/2/3/4/5/etc.
5 Dec 2011 at 16:26 #3 Confused Confused Soldato Joined 18 Oct 2002 Posts 8,015 If you're using Windows XP, Quick Launch, or Windows 7, pin them to the taskbar. No need for a 3rd party program to do something built into Windows for years!
5 Dec 2011 at 16:44 #4 Jon123456 Jon123456 Associate OP Joined 5 May 2011 Posts 133 Not much space on the taskbar. I might have about 20 docs/apps that I use frequently. I've installed RocketDock now, for the win. Last edited: 5 Dec 2011
