- 6 Sep 2016
I have put down some cat 6 cable down at the moment it's just running through the door but I want to put it under the carpet strip.
It's carpet to carpet. What tools need to lift the two sides a.little and put cable between the door frame and carpet strip?
It's not nailed or screw down type it's probably the one with hooks pointing inwards on both sides. I don't need to remove all the carpet just wnough on either side and on other edge as two cables, from room to room.
