- 5 Aug 2020
Top 4 Entry Level Sewing Machines by Singer Under $550
Are you a big fan of a singer brand and looking for the
best sewing machine for beginners to start your career in the sewing field but your problem is budget? The Singer is the kind of brand that has something for everyone in the market and you can always find the right sewing machine for yourself by this brand. Today we are suggesting sewing machines to you that fit your budget.
These smart computerized sewing machines are available for under $500 and you don’t have to go beyond that. These sewing machines are strong in performance, efficient in speed, and durable in appearance. You will be satisfied with the stitching quality as a beginner but you must choose a sewing machine after identifying causes you need a sewing machine for. Let’s go through our short-listed sewing machines.
1 - Singer Confidence 7465 Sewing Machine:
Singer Confidence 7465 sewing machine has a strong motor and it’s durable enough to sew multiple layers of fabric. Sewers who have started their home sewing business and they are still at beginner’s level then they should go for this sewing model.
Pros:
Singer Confidence 7465 sewing machine has 50 built-in stitches, 2 buttonhole styles as well as 13 needle positions. These basic features of this sewing machine are essential for any professional home sewer.
This model has embroidery features, automatic thread tension, LED Screen, automatic needle threading system, drop-in bobbin system, and 6 stitch memory store for your ease.
The whole and wide range of accessories include general purpose foot, zipper foot, buttonhole foot, blind stitch hem foot, lint brush, small spool cap, soft dust cover and auxiliary spool pin.
This sewing machine also has 2 LED bright lights to illuminate the whole working area when you are working in late hours at night. You can take a closer look at stitching with these LED lights.
Review:
Singer Confidence 7465 sewing machine is efficient and strong enough to provide everything to a newbie user they are looking for in other simple sewing machines. This model is user-friendly so a user doesn’t have to read manually again and again to understand the whole mechanism. The way this sewing machine handles fabric is exceptional.
❖❖❖ Find More Info: CraftsSelection.com
2 - Singer Start 1234 Portable Sewing Machine:
Singer Start 1234 Portable sewing machine is the portable and smartest model you can come across. It’s user-friendly, basic and loaded with modern-day features. This singer sewing machine is a quick starter sewing machine so you can start working right away. From single thin fabric to fancy fabric, this sewing machine can do anything.
Pros:
This sewing machine only weighs 7 pounds and you can travel with this sewing machine anywhere. This model has 6 built-in stitches with 4 step buttonhole.
This sewing machine has an automatic bobbin winding system and you can also learn how to do it by looking at the diagram printed at the sewing machine.
This model is full of accessories so you can work in peace and you don’t have to invest in sewing accessories for a long time.
The appearance of this model is quite elegant and you can select any stitch of your choice by moving dial located at the front of the sewing machine.
Review:
Singer Start 1234 is the best starter sewing machine that can help you in completing the work quickly. Instructions written on this sewing machine are easy to read and even if you are using the machine for the first time, you can simply learn to use it.
3 - Singer Heavy Duty 4411 Sewing Machine:
Singer Heavy Duty 4411 is the kind of sewing machine that is efficient enough to save you lots of time and with the help of smart speed, you can finish multiple projects in a day. From pillows to curtains you can sew almost anything with this sewing model. You can sew almost any kind of fabric from this sewing machine.
Pros:
This sewing machine has 11 built-in stitches including stretch, basic and decorative stitches.
The construction of this sewing machine is quite strong and you will love how durable it is. It can work for a long time without any damage.
This sewing model has top drop-in bobbin with clear cover, adjustable stitch length, reverse feature, extra-high presser foot lifter, and free-arm feature as well.
This model can help a user in dealing with multiple fabrics at the same time and there will be no compromise on the stitching quality of this sewing machine.
Review:
Singer Heavy Duty 4411 is a durable and long-lasting sewing machine you would love to use to design professional projects. This sewing model is providing you desired results without compromising on any of the features or speed. You will be impressed with the performance of this sewing machine.
4 - Singer Curvy 8763 Sewing Machine:
This good sewing machine for beginners is extremely reliable and suitable for beginners level sewers. This sewing machine is inexpensive and can deliver great results. From the appearance to the performance, this sewing machine is impressive in every sort of section.
Pros:
Singer Curvy 8763 sewing machine has 30 built-in stitches including basic, stretch and decorative. You can sew anything from fashion to quilts and crafts.
This sewing model has a swift smart threading system for quick and smart threading of machines.
Drop and sew bobbin system in this sewing machine allows you to keep an eye on the bobbin and you can wind up bobbin before thread will be finished.
Singer Curvy 8763 has the potential to handle almost any kind of fabric. You can customize every project through this model.
Review:
Singer Curvy 8763 sewing machine can provide consistent results all the time. This model can be a great addition to your sewing room and because this sewing machine is user-friendly you will enjoy working on this model.
✪✪✪ Related Article: Top 5 Best Singer Sewing Machine Reviews and Comparison
Conclusion:
You should always do complete research on our favorite brands like if you love Singer machines then you should get your hands on the best one. Sewing machines are of great importance in adding quality and professionalism to your work. All the machines mentioned above are perfect and will give you a neat experience in terms of stitching.
![CtrfNrK.gif CtrfNrK.gif](https://forums.overclockers.co.uk/data/attachments/376/376867-d8913410da9eef29cfa35b9934e8587b.jpg)
![6x9XcDj.jpg 6x9XcDj.jpg](https://forums.overclockers.co.uk/data/attachments/376/376868-c38a87b0349d511fea9d9f86d7668e0f.jpg)
Pros:
Review:
![AUCkCxS.gif AUCkCxS.gif](https://forums.overclockers.co.uk/data/attachments/376/376869-c507caadd88a1afdfa45293eeaa617fa.jpg)
Pros:
Review:
![dzJCJqL.jpg dzJCJqL.jpg](https://forums.overclockers.co.uk/data/attachments/376/376870-db739870676204e8325caa47382a7904.jpg)
Pros:
Review:
Pros:
Review:
![JxKoW0u.gif JxKoW0u.gif](https://forums.overclockers.co.uk/data/attachments/376/376871-7dfe9e13867d0663bcd5503e8908031d.jpg)
Conclusion:
