- 31 Aug 2007
Hi all. Sorry for being a bit of a noob here just wanting to double check things before i start cutting. Also the how-to on this in the case mod forum doesnt work, dead link. Does anybody have a link to a good guide? Is it possible to do it with a jigsaw or does a hole cutter need to be used? The friend cutting it for me is a joiner.
Would there be any airflow problem with the current 2x40cfm fans (1 intake & 1 exhaust) and a new under volted 120mm running very slowly? There also the PSU fan and 8800GTX exhaust but im assuming their airflows are negligible. Specs of fan im going to use: 2000rpm, 54CFM, 7-13V. Temps dropped by 10C with air leaving under natural convection so the fan doesnt need to be running fast.
The plan is to cut the hole, smooth it and then put a strip of U-shaped rubber around the hole to make it look nicer. Under this will go a 120mm fan vibration dampener, a 120mm Aluminium black mesh fan filter (again make it look nicer), another vibration dampener and then the fan itself. The reason for the dampeners it to lift the filter away from the U-shaped rubber to stop it pressing into the fan. Would the under volted fan be strong enough to push air through the filter or would a sheet of open guage aluminium mesh be better? Im thinking entirely asthetics here.
Finally two small questions.
1) The case mesh that is infront of the case fans, I know people cut this out for better air flow, but does it actually have an effect?
2) My HD was infront of the front intake fan with air flowing over the top and bottom, its temp was 27C. Now that air is only flowing over the top and the bottom is flush with the case its temp is 35C. Im assuming the temp sensor is on the underside circuitry and not inside? Would adding a small fan down there help things?
Thanks for any help.
. Still 3 issues:
) but I'm sure it will be back in shortly.
