Jokester said:Can you do it again, with only measuring the actual current used by the PC PSU?
Jokester
Tad OT: Why do you have a 7300gt as well?
CS||nuTs said:Was there any fluctuations,i mean major ones?
That is simply awesome! Hoped it would be close to what i said but didn't truly believe it would be!james.miller said:so what do you think then? and well done gt_junkie and Craig_kennedy83 for guessing virtually on the button![]()
james.miller said:not as far as i could see. unfortunately the equipment didnt measure in watts so the best accuracy we had was to withing 0.1amps, 24watts basically. even given that, the total draw was still WELL below with would officially be recommended for the pc. given that the 384w (1.6amps, although in reality it could have been +/-12w of that figure) figure was for everything connected to that strip, its not unfiar to say the draw of the pc could have been closer to 360w or less.
PhillyDee said:im gonna guess at 175W For the rig only. So im gonna go with about 384W full load.
My whole rig as per spec, + speakers, 20.1" tft, modem, router, and cordless phone pulls 280W. Thats idleish though.
Do i get a prize?Gonzo0 said:My jeantech Storm 700W PSU has a power usage read out on the back![]()
james.miller said:ok well its been half an hour.. i was expecting more replies but maybe people are worried they'd get it wrong
anyway with the tester plugged in i booted up the pc and straight away we saw a 1.2amp load. 288watts, in other words. that's a fair amount considering it wasn't doing very much and did suprise me some what, but booting in to vista saw a 1.3amp peak (312watts) as the optical drives span up and it did its thing which wasnt a huge increase.
as I ran superpi on one core and 3dmark's nature tests on the other, the maximum peak was 1.6amps, 384 watts. that's it, thats all it could muster lol. This is only a short test but if nothing else it does prove that recommended ratings and 90% of what people will tell you you *need* on a hardware forum.....is complete tosh.
Millwall.FC said:i think its flawed you need to test after the psu.
james.miller said:how is it flawed? i tested the entire draw from the wall socket. you can get much better than that
Jokester said:Yeah, but it's including things not powered by the PC PSU, the monitor alone will use something of the order 60-80W.
Jokester
the only thing that you can say for sure is that *** draw of the pc alone would be even less, but that makes no difference to this test.james.miller said:how is it flawed? i tested the entire draw from the wall socket. you can get much better than that. If you test after the psu then you aren't accounting for additional draw of the psu as it isnt 100% efficient. As you know, the psu is also part of the pc
james.miller said:he isnt talking about that jokester, and i did say it was the draw of the entire setup. its not a flawed test as i tested exactly what i said i would![]()
