top fan no working
17 Nov 2008
i have a Antec 300 Three Hundred Ultimate Gaming Case and the top fan has stop running will it be ok for the computer keep running. cpu fan ok and the one at the back ok ....cheers
No worries. You can get replacement fans anyway if you find your temps become an issue without it. Its a 140mm so for about a tenner you could find another
I know it sounds stupid, but have you got it plugged in correctly? No cable in the way of the blades?
I made that mistake! took the whole thing out and just as I lifted it out of the case the wire snagged on the fan and made itself known :( frustrating! lol
Always check the silly simple things first :)
