I have 3 120mm fans at the front of my case as intake, and no exhaust fans but I do have my Corsair H80i fans as exhausts at the rear of the case and I have two blower style GPUs that also exhaust air.
This seems a good setup except when the system is going at full tilt and I end up with a ton of negative pressure (the front intake fans are running at max speed all the time but that's not particularly fast). I've ordered another couple of fans and was thinking of installing them in the top of the case as intake fans (labelled in the manual as a spot for exhaust fans but it has a magnetic filter so I'm guessing it can be used either way?). I'm fine with negative pressure but another couple of fans would increase the flow of cool air they have to work with but would disrupt the current flow of air from front to back of the case.
Anyway can anyone see any downsides to doing this or have any other ideas on how I should arrange my fans?
The blower style GPUs and H80i exhausting all their hot air outside the case is potentially an ideal setup but it's a shame my temps don't currently reflect that...
