Permabanned
- 9 Jun 2009
- London, McLaren or Radical
I am struggling to find a component for my new build.
I want one of the reservoirs to be top-fill... ie, the water enters from the top and exits at the bottom.
I have seen a number of decent WC builds have the component I'm looking for... but I can't seem to find one anywhere.
It's the tube that extends from the water input to below the water level... to stop the trickle noise and vortex created by top-input.
Anyone know what it's called or where to find one?
It's for a Monsoon MMRS reservoir if that makes any difference, but would assume there are G1/4 fittings that should fit any tank.
Thanks
Thanks
