top mounted rad fan direction
24 Jun 2009
After many hours of reading about having the rad fans pulling air through and exhausting out the top of the case versus them blowing through the rad into the case, I decided to try for myself and thought I'd put up my results.
I am using x3 xigmatek crystal fans at 1500rpm in pull but set as intake.
With a mild oc of 4.4ghz using offset volts, my 2500k reached an average of 50 degrees across all cores with an ambient of 22 degrees. This is about 8-10 degrees less than I was getting with the fans exhausting out of the case.
I was worried dumping heat into the case would have an effect on my gtx 480 but it hasn't as the temps are the same and I have a 99cfm fan blowing directly at the card if needed using the gpu duct :)
So, which orientation are your top-mounted rad fans?
