Top of display missing in BIOS when using Display Port
22 Jan 2008
Hi, not sure if this is in the correct section ...
Just got new parts for PC upgrade ( all from OCUK ) comprising of ...
MSI X570 Tomahawk (updated to latest BIOS)
Ryzen 5600X
Sapphire 6700 XT Nitro ( got this when Gibbo done that great offer, thanks OCUK )
16 GB Patriot Viper 3600 Ram
WD Blue SN550 1TB for Windows
WD Blue SN550 2TB for Games
Old reused parts ...
Noctua NH-D14 with new Noctua NT-H2 Thermal Paste
Super Flower Leadex Platinum 1000W PSU
Crucial 1TB MX200 SSD for general storage (not currently installed)
BENQ XL2730Z 144Mhz Monitor / supplied Display Port cable
New 8k Display Port 1.4 Vesa Certified Cable
When entering the BIOS using the Display Port cable, the top 2 inches of the screen is missing, when windows loads the screen is fine, also plays games no problem.
When entering the BIOS using an HDMI cable the screen is all there.
I've tried plugging into different ports on the card and it's exactly the same top of screen missing only in the BIOS when using Display Port, I've bought a new 8k 1.4 VESA Certified Display Port Cable and that is the same as well.
Anybody else had this problem? and if so how did you fix it
There's no options for Display Port settings on the monitor apart from selecting it from the menu list of which input DP / HDMI / DVI / D-SUB
Display Mode Setting on Monitor Menu is Full
Monitor Scaling in Windows is set to 100% (recommended)
Install is UEFI
Tried PCIE Gen on Auto / Gen 3 / Gen 2
