 - 10 Apr 2014
 - Hampshire
Anyone got any tips on how to properly set up fan pins? At first i was doing it the normal way you would with atx pins for a gpu/motherboard.
I have the right pins but when i crimp them and then put it into the connecter i hear the click but the connection isnt too strong, i can always pull it back out without using too much force.
When i try to pull out the pins on my vardars that havent been extended yet, they wont even budge when i use the same force.
Anyone know what i could be doing wrong ? Another thing i think i should mention is, i have to cut little wings off the side of the pins after taking them from the row.
