Torn between 3 monitors 1440p
I personally went for the Dell, I was about to pull trigger on the 2412 and then noticed the 2515. Just a great monitor (which I'm yet to play FPS on).
No experience of the others but thumbs up for the Dell.
The Iiyama is TN and the other 2 are IPS
All 3 aren't really great for FPS gaming if that's your thing, I bought the Iiyama and sent it back, unboxing and first impressions seemed good but problems started to develop after a few hours, stuck pixel, Freesync didn't seem to work properly, colour banding and washed out image and the refresh rate is 70hz not 75 like it suggests but mine was faulty
Weird because my 3 old Iiyama is amazing, better image, much smoother and no faults what so ever
I've also got the Dell and it's the best monitor I've ever owned.
I swapped out a 144hz Benq for the Dell - I prefer FPS on the Dell too, yes it's not as smooth but the colours are better, as is the black depth, and going from 1080p to 1440p makes a big difference.
Thanks Minstadave for your advice..one more question would the extra 2" make a difference,say if i could stretch to paying for the 27" model (is it worth the extra 105 quid?)im currently on a 24" IIyama prolite B2409HDS,or would this 25" be plenty..Thanks Pal
Cheers Pal,you,ve just made my mind up for me,shame its an extra 25 quid dearer on OC than Amazon as i only live minutes away from OC warehouse,Thanks again Mate
Will do Minstadave,and again cheers for your advice,looking about it looks like i need to purchase a display port cable for this monitor as one does,nt come with it is that correct?
