I'm in a little pickle at the moment.
I'm currently in the process of changing coolers on my 8800GT as my trusty Zalman VF700-AlCu (which is the part copper/part alluminium one) is on its last legs.
Now I do not have much choice in coolers as my PCIex1 slot is directly below my GFX Card and I use it for my wireless so big heatsinks with 80mm fans strapped to them is a no go.
So, I have managed to squeeze it down to 3 choices. I have trawlled the net and found that all 3 fit the 8800GT reference so its all good there.
Present temps with the VF700-AlCu are 45c idle and 62c load so not bad.
When I get either of these, I will have a further 8 ramsinks totalling 16 so I will have some spare to go on the mosfets etc...
Which one do you think would be the better?
The Zalman VF700-Cu
The Zalman FS-V7 Fatal1ty
The Zalman VF-900
The Zalman VF700-Cu
The Zalman VF-900
