- 28 Oct 2002
- SE London
I'm in the market for a new laptop - I want something which can do a bit of gaming, I don't play anything too intense, just WoW\D3, but I also want it to be able to handle multiple VMs too (doing MCITP, I plan to rip the disk out, replace with a 120Gb SSD, use the mech externally and sync what VMs I have on my server to my external disk so I can continue working on them on the road)
I have seen 2 laptops which have caught my eye in the price range I am looking at (<£800), they are as follows:
Alienware M11x R3, i5-2467M, 540M, 750Gb HD
pros: ultra portable, good battery life, decent graphics, upgradable to 16Gb of RAM (++)
cons: less powerful CPU\slightly lesser GPU than the other option
Lenovo E530, i7-3612QM, 630M, 320Gb HD
pros: more powerful CPU, 4C8T, slightly better GFX
cons: much bigger, 15.6", upgradable to only 8Gb, can get ~3.5Hr real time usage from the battery
They're both roughly around the same price, I just don't know which to get. I have laptop bags to suit both sizes, the weight differential is marginal, .2Kg I believe, the only problem would be with getting the Lenovo is that I'd have to stop using my STM bag which is designed for a <13.3" and an iPad in the same bag, and get an iPad hard\all over cover for it as the STM has a dedicated pocket for an iPad.
Ideas? Suggestions? Anything which you guys can think of which'll fit in between the two which I am looking at?
Thanks!
Thanks!
