- 6 May 2008
Hi all, just wondering what torrent application you use, and also do any of you bother using torrent encryption, and also what do you set your upload speed to?
By accepting incoming legacy connections does that not negate encryption? I.e., some connections are AS-IS.
Well, if your using forced encryption i assume that all connections through bittorrent are encrypted and apart from the fact that you are obviously using P2P anyone including your ISP will be unable to determine exactly what your downloading?
