Lookup your modem on http://portforward.com/ then follow the instructions. You'll either need to know the current port number your Torrent app is using or choose another one and use that in the router and the torrent app.MofoKilla said:How exactly do i setup portforwarding ?
UKFSN are an Enta reseller and as such don't throttle.Hessian said:Within uTorrent there is an encryption options which is for users that feel their ISP is slowing their d & u via p2p.
Yeah it really works. I used to download RyanVM's update pack for XP/nLite and would struggle to get any decent speeds with uTorrent. I had a red cross or whatever at the bottom.lemonkettaz said:wow.. port forwarding reall works..
ive been struggling with bt homehub since i been back home from uni... just did a dabble at its much better
