torrents killing browser activity (bt home hub)
14 Nov 2007
I understand about capping upload speeds, so it's nothing to do with that. I've got plenty spare.
After starting a torrent browsing is just dead, after a time it picks back up. Unfortunately I've never timed it, but torrent speed has nothing to do with. Someone suggested to me it might be the amount of connections my router is set to handle and how long expiration of the connections is adjusted for.
This made sense, but I couldn't see anywhere to up max connections or change how long they last in the home hub. I hope this makes sense, I spent some time at the pub :o
Why that never occurred to me before... I dunno. It seems to have worked, though. I cut the connections in half on my torrent client, and I'm going to keep bumping them up till I find a limit. Thanks.
If your using a torrent program:
1) Set your maximum number of global connections to 180
2) Maximum number of connected peers per torrent to 60
3) Upload slots per torrent to 8
4) Make sure your upload is set to 80% of your upstream (no more than this either), put in 25KB/s if your not sure
Post back how you get on :)
I had this problem with my netgear. I fixed it by logging into the router and disabling deep packet inspection in the firewall config. Maybe the home hub has something similar.
