Toshiba 32wlt66 and xbox360
28 Nov 2003
bicester
Been trying to hook up my 360 to my brand new tosh 32wlt66 via hd component but i aint getting a picture??...works fine via the vga lead .Anyone using this tv via component? shed any light? :confused:
Solved it.I had to remove my gamecube from the av3 input as it overides the component input for some strange reason.It looks so much better in 1080i than using the vga lead .
This is exactly the set up I was loooking at getting, is the pic any good from the 360??
Do they go well together, is it a marriage made in gaming heaven :D
The max res was 1366x768 via vga but it looks a bit bland.Using component it looks much more vibrant and you get better compatability with xbox 1 titles.
The picture quality is quite superb ,the 360 and 32WLT66 go together very well indeed £800 well spent :cool:
