Hi all
I recently changed the CPU in my Toshiba satellite l750-1ek
it has 8gb ram
It had an i3-370m, I put an i7-640m in
since then, the fan regularly speeds up, and as it does it freezes, it also hangs the cursor quite often so I can't move the mouse around, but it seems I can open things, and also things all run rather slow. After I changed it over, I gave my i3 away, without fully testing things, I saw that it came on etc and handed it over.
Now can I sort this with some adjustment to some settings, in the bios maybe? Ive looked in the bios, and it looks very basic to a normal bios, I can't seem to change anything really, . Any thoughts on that?
Could the i7 be faulty?
Or could the problem be that my Toshiba just can't handle the i7 properly?
The original i3 is only about £5 on ebay, so could put one back in.. Or should I try buying another i7 to see if it is faulty, or even going for an i5 or something?
Any thoughts? apart from buy a new laptop.
There was nothing really wrong with the i3, but like most people, I just wanted to tinker, and know it had the best it could have.
thanks for reading
it has 8gb ram
thanks for reading
