- 7 Jan 2007
- Sussex, UK
Hi,
Just pre-ordered this telly for £570 delivered.
Specs are:
My budget was £500-£600, The only grip I have is that I have seen 1080p on my mates 32" sony and I couldn't tell the diff between that and my 720p set on blu-ray.
Is 1080p on a 37" worth it considering I sit between 5ft-12ft away, depending where I sit in my room.
Specs are:
Code:
1080 HD Ready
Freeview Digital Tuner
Display Resolution: 1920x1080p
Dynamic Contrast Ratio: 18,000:1
Brightness (cd/m2): 500
HDMI: 3
Main Specifications:
Visible Screen Size (cm): 94
Screen Format: 16:9
Active Vision LCD
Standard TV up-scaling
Exact Scan Mode
MPEG Noise Reduction
Selectable Picture Format
3D Digital Comb Filter
Digital Noise Reduction
Viewing Angle: 178
Luma Sens (Auto Contrast)
10-Bit Processing
Full Power Down Mode (On/Off)
Game Mode
Connections
HDMI: 3
Component video
RGB (via SCART)
SCART: 2
Side AV input
PC Input: WXGA
Analogue Audio Input
Fixed/Variable Audio Output
Optical Digital Audio Output
Headphone
Sub woofer output
DVB Common Interface
REGZA Link (CEC Functionality)
S-Video
