Toshiba Sattelite L40 keys rattling when listening to radio
11 Mar 2007
Hi all, i got one of these Toshiba laptops from staples the other day for 350 quid and i straight away i noticed that a lot of talk radio stations cause the trackpad keys to vibrate loudly.
I'd expect this near the top of the volume range but you can still hear it with the volume below 50% and if i damp the buttons with my hand the keyboard starts to resonate even louder than the trackpad buttons.
I dont suppose anyone else has one of these and is experiencing anything similar?
Otherwise its a lovely pc, fantastic screen and other than the vibration problem the sound is really decent.
I'm pondering taking it back to Staples but if its a general fault with this series i'll have to replace it with a different brand.
Cheers :)
i have noticed on some laptops that certain frequencies can cause vibrations have a tweak of the graphic equaliser and you may be able to alter a few of the sliders to help it. or if you not happy with it take it back.
Yeah i narrowed it down to around 600k but i have to remove so much of it to stop the rattling that it sounds terrible, i think i probably will end up returning it.
