- 28 Nov 2009
- Manchester
http://www.overclockers.co.uk/showproduct.php?prodid=GX-222-AS&tool=3
Took a look at the 400 series shop...obviously there were none in stock, but saw a 480 had reviews...five to be sure. The asus 480 has a rating of 4 stars due to five people...who dont even own the card.
Seriously what kind of <<<beep>>> would think he knew enough from what other people had said about the card to either warn or encourage others about it in a shop- forums are one thing but this is a whole other level!
Some quotes for your amusement...
Unt ze best;
Surely this should be moderated? These guys dont even own the card! Although it is pretty funny other idiots might listen to their garbled bs...
Ah, thank you sir for your judgment on something you have never seen or touched that flies in the face of what everyone who actually has done says.GTX480 - 1 GPU requires 600w...Too Noisy & Becomes really Hot after a while & feel the system heating up, you will have to leave the case open
If anyone manages to find and afford 4x480 it is likley that nations will bow down to them as their PC room gets recognised by the UN as a nuclear state.If you really wanna rub it in then get 4 and run them in 4 way sli, water cooling is advised for such a crazy set up, but will surly make every other pc enthusiast bow down to you.
Ahhh...a sensible qualification of your previous statement...you want to beat 5970 cf then order 3
What are you basing this on?!?!go for this if you plan to water cool it, otherwise it's gonna be too hot or too noisy for SLI
Thank you for sharing your wise judgment.By the reviews, seem to be a good vga
Thats right folks if you took 3D features off the 480, it would be super...dooper...fast. And if the 5970 was given CUDA and Physx it would be slower than a glacier.GTX480 - without Physix , Cuda & 3D features it would be the fastest GPU on the market
If ATI 5900 had these features it would be too slow to keep up with GTX480
Unt ze best;
Genius.This is the fastest gpu on the planet granted there is a faster card
